Base Station offline
  • 1 Reply
  • 716 Views
MakT
Base Station (single light) offline along with all cameras connected to it. Cameras directly connected to wifi are working fine, as is my internet. Base station hard wired to internet, cables all fine.
Disconnected all cables, waited 1min, reconnected ethernet cable first then powered on. Still offline.
not the first time this has happened, last time had to hard reset and redo ALL settings on the 6 cameras!
Help, please
What is the base LED showing? If it's blue, it's not offline.
You may want to try power cycling the router and base, in that order.
