I have 5 all-in-one sensors, and all 5 went offline a few days ago. All 'sync' buttons and replacing the batteries don't help.
I tried to re-add the sensors to the Keypad hub by removing the sensors from the Alro app, placing the sensors next to the keypad hub, pressing the `sync` button for more than 10 seconds, and waiting for the blue light to come on. The Alro app continues to search for nearby sensors, but none of them are found. them detected.
That would seem to indicate the security hub may be the issue. Have you tried power cycling it (removing the backup battery, too, if installed)?
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
