Activating the arlo cameras
  • 2732 Views
Skipper188
It looks like arlo security is going away   . I bought a arlo security system from Costco around 2 years ago so I must have the old system . I would like to activate my cameras so what do I need to do now ? Or should I not since it may not be around ? I'm confused as what to do
Please give us more details on what you bought.  Also it would be helpful to know if you are re-installing the system, or if you never installed it.
If you purchased a base/smarthub, then look for a VMBxxxx label on the base.
If the cameras can be removed from the housing, then open the cameras and remove the battery.  You'll find a label inside.
If the cameras cannot be opened, then look on (or near) the seal around the charging port.  There is some fine print there (unfortunately low contrast) that provides the model number.  Taking a picture, and then reading the text from the enlarged picture sometimes is easier than reading it directly.
Skipper188
It's very difficult for me to take the cameras down to get the info on the inside . They're way up and I have to get up on a ladder. Is that totally necessary?
Likely, yes.
When you said earlier that you wanted to "activate" the cameras, what exactly did you mean?
