  • 4 Replies
  • 1616 Views
kingdomcome
Arlo Professional Monitoring is not responding to triggered alarms. (New installation - less than 30 days.) They are also starting to seem disinterested in my request for support, by hanginh up on me (no, I'm not being rude). Anyone experiencing similar problems professional monitoring? Arlo tech support seems to imply I'm not getting a "call back" because I have a "new customer - trial subscription". This seems to be counter productive to their desire to gain more customers and sell the higher cost subscription plans. Any ideas as to how to get professional monitoring from Arlo professional monitoring service?
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
BrookeN
kingdomcome
No, I have not accepted a solution. There was no solution offered. I've been struggling with the same problem since I purchased the system.  Professional monitoring is not responding to triggered alarms.  I am not able to determine if the problem is a result of initial setup and installation. I've restarted my modem and system hub. Nothing I do seems to make a difference.
I've tried to follow every trouble shooting tip suggested. Nothing seems to make a difference
kingdomcome
I can't seem to figure out how to turn on DM . I can't find "preferences" in profile settings.
Note this is a forum feature, not your my.arlo.com account.
The envelope icon is here:
The settings are here:
