2 questions about Arlo security systems
Moving away from Ring cameras and alarm. Arlo cameras: great. But 2 questions to confirm my research about Arlo alarms:
There are no Arlo range extenders for alarms? The only option is to, basically, use a 2nd base station unit to create a 2nd alarm system in my house, so with Arlo I have to have two entirely separate alarm systems to cover my house? Really? Seems like an odd miss on Arlo's part.
Only option for window open/close sensors are all-in-one sensors, which are much larger and more expensive than non-Arlo options for windows?
Just want to confirm if I have missed anything in my research so far.
Thanks!
Correct. Only Arlo devices can be used, and the only sensor is the all-in-one sensor.
You'd need to add a second keypad, but the system overall would still function as a single system. ("Base station" is a ambiguous term, since it generally means a base/smarthub for the cameras - something else altogether).
Hi @Retired_Member
Also, in case this helps, Arlo has a wire free keypad that connects to the keypad sensor hub to extend that range in case maybe you wanted a device downstairs and upstairs, different rooms etc. You can find that here
Feel free to reach out anytime if you ever have any questions. We're always here to help.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
