2 homes, 2 base, app won't separate
I have 2 homes in different states. With new update, I can't turn one off without the other turning off. Same goes with turning them on. Can you separate the two like before?
Before it was simple to tap one button to turn a home off or on.
Thank you for your help.
You need to set up different locations in the app (one for each home), and then put the devices in the correct location.
Note if you have a subscription for cameras in both places, you will now need one for each home.
To make sure I understand correctly. I now need 2 subscriptions. one for each home?
If you set up two locations, you will need to do that. FWIW, that was always in the terms of service, but wasn't enforced (since the app didn't have the concept of locations).
If you can live with the current situation, you could see if Arlo restores the custom mode feature. That might give you what you need with only one subscription.
Thank you for your help!
Sounds like, in my case its time to move on.
There are other camera companies that are cheaper and better customer service.
Thank you again for your help.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
