  • 6 Replies
  • 2186 Views
SorenDK
Android: When turning off notifications under geofencing mode it turns on automatically after a while and is not working? Keep getting away/home notifications.
Any suggestions? Thanks
6 REPLIES 6
JessicaP
Hey SorenDK,
Just to make sure, are you saying that you turned off the Geofencing push notifications for your device through the Arlo app but you're still receiving them?
SorenDK
Hey Jessica, yes that is correct. Turned off push notifications and saved in geofencing mode. When entering the zone it will automatically switch on again.
SorenDK
Also when closing the arlo app or logging out and opening it again the push notification is switched on..
JessicaP
Have you tried reinstalling the Arlo app and restarting your Android device to see if that helps?
SorenDK
Jep, also tried earlier versions of the arlo app to no avail. Was hoping someone else have had this problem and could give me a clue. It's the only thing that doesn't seem to be saved. Hmm.
JessicaP
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 6 Replies
  • 2187 Views
