Hi, I have 2 Arlo go cameras and 6month ago they probably filmed and incident. Is there any chance to get what they have filmed? If yes where I can get it?
If you don't see the video in the library (which you won't, since retention isn't 6 months with any plan), then you are unfortunately out of luck as far as cloud storage is concerned.
Did you put a microSD card in these cameras? If you did, then you could eject the card, and look on a PC.
Modes et règles
