VMB 4540 Base Can't Add Device
  • 4 Replies
  • 3012 Views
ellien1978
My original Arlo base died and I bought a new base on Amazon and tried setting it up as directed but I can't get it to sync with the app. I have tried all the trouble shooting steps, reset the brand new base twice and ran the network speed on the app and it looked good but still no luck. I had two different online agents attempt to help me but all of their steps were the same ones I had already tried with no luck. Any ideas?
Have you tried onboarding the base from both the app and from a PC (my.arlo.com)?
ellien1978
Yes, I just tried desktop too. 😞 Maybe something is wrong with the base.
Could be.  Are you seeing the base in your router's attached device list?
ellien1978
It does. I just unplugged router, Arlo and did factory reset on everything and it finally worked. Thanks for the input
  • 4 Replies
  • 3013 Views
