  • 2334 Views
Scholdis
I have heard that solar panel 4030 is discontinued without replacement product for Go? Is there no solar panel that works with the current Go-model? Is vma5600 compatible?
Am living in Europe (Sweden) where no new model of Go is available and apparently no solar-panels either!
Understand we await the new model, but until then it then seems like no solar panel is offered to the existing (old) Go-model!? Is that correct?
Unfortunately, it is not.
Scholdis
Many thanks Stephen. I then guess it is currently no solar available?
Many thanks
It appears that supply chain issues are rampant. A quick search for Pro 2 solar panels (the same as for the Go) shows only 3rd party ones. You can try those (if available) but there have been reports of incompatibility for whatever reason.
  • 2335 Views
