  • 1 Reply
  • 4000 Views
alien_scones
Is it only me, or has anyone else observed that adding a solar panel to the ARLO Go only makes the battery drain faster?
Two deployed cameras with recharged batteries set out at the same time.
One that has a functioning solar panel is at 30% and the other (with a solar panel, but never shows charging) is at 70%.
in the meantime, for your viewing pleasure - whitetails snacking during a Texas thunderstorm:
Can say there are blocking diodes on the solar panel, so the panel shouldnt drain the battery ( back feed )...
as to why one drains faster, it could be signal levels for the Go to reach the cell towers.
As to not charging, When tested, I found the panel only charged a few hours before/after noon in bright sun..at other times, not enough sun to charge ( or make a difference ) ... check the sun angle in your placement to assure good sun levels
  • 1 Reply
  • 4000 Views
