Can I Run Arlo Go with the power adapter without the battery?
-Arlo Go VML4030-100PES SN: 51D Location: Sweden FW: 1.096.3.1_1.8.63.0_0 .6.5.19.GC.002 -
Yes but the battery allows the camera to keep working without wall power.
10 REPLIES 10
Ok I'm thinking about removing the battery because the cold weather is draining it. First I couldn't charge it because it was to cold, the app said. It was about -2 Celsius here.
I charged the battery full yesterday inside the house and I have the battery adapter connected all night and now the battery is down to 21%....
When AC power is applied, the battery shouldn't be used at all - it runs off the connected power. Are you using the Arlo/Netgear-supplied charger and you get the proper power icon (battery with a lightning bolt or a wall plug)? Something's not right if the battery is draining.
Yes I'm using Netgear charger and I get the charging icon that's shows that it's charging
And when it's connected does the battery ever charge?
Yes up to 100% and when I charged inside the house. I have now removed the battery and use the ac adapter
What can be wrong when the battery is drained over one night?
Poor cell signal strength or quality, too much recording and/or live viewing, faulty battery or camera.
Ok it was overnight with no recording maybe poor signal
Modes et règles
