Outdoor uprade
  • 1 Reply
  • 3065 Views
Lordis243
Looking to add a couple cameras to older arlo go cameras (which i like)  have a  ?.. can I change the settings to record for longer than 5 seconds each time there is movement?
And can I view or manually record more than one camera at a time?
I have power and wifi reaches to where I will install the cameras. Thx
You've always been able to set the recording time for more than 5 seconds. Those settings are in your modes and rules. As for viewing and manually recording more than one at a time, the general answer is yes. Since you have Go cameras, there's no limit - only those connected through a base station or SmartHub have a limit of 5 at a time.
Be aware that any new camera you buy now has to have a subscription for cloud recordings.
  • 1 Reply
  • 3065 Views
