Help locating a solar panel
  • 1 Reply
  • 1883 Views
fabrizio75
ave non riesco a trovare un pannello solare compatibile con la Arlo go primo modello potete indicarmene una  un link dove posso acquistarla il modello le specifiche grazie
I am assuming you mean the original Arlo Go, and not the Go 2.  You do need to be careful on this, as panels that work with the Go 2 will not work with the original Go (and vice versa).
The Arlo part number is VMA4600.  But unfortunately, Arlo no longer sells it.  You might be able to find a used one (or old inventory).
  • 1 Reply
  • 1884 Views
