I have an Arlo Go which also includes a night stand. Now the image remains dark! I do not want the camera to be discovered by a light on the camera ... Does anyone have any experiences with that?
If your saying the IR isn't working, then attempt to fix by reset of the camera ( pull and replace battery )
If you saying you don't want the IR to be visable ( they glow slightly red as they are 850nm freq ) that isn't fixable... they are either on or off... only possible option may be another external IR source out of the visible range that the camera would still see ( maybe 950nm )
Thank you for these suggestions! I understand that in normal night mode there must be a clearly visible picture. This is not the case with me. Gr Patrick
Modes et règles
