  • 7 Replies
  • 8013 Views
StevenPaul
I have three Go cameras. On the app, the microphone icon is greyed out for all three. How do I activate the mic button?
7 REPLIES 7
Is the mic enabled in Settings, My Devices, your camera?
I found the browser to also make a difference with the Q..( I know its the go )... try Chrome of FireFox
StevenPaul
Are you referencing the Settings on my iPhone or on the Arlo app? If the former, I don't see My Devices as an option. If the latter, I don't have a camera option under Settings. Sorry to be so dense.
If this is any help, when I live stream my camera, not only is the microphone icon grayed out, but also the two icons to the right of the pause button are grayed out. I have good sound from the camera to my iPhone app.
Thanks for your guidance.
StevenPaul
Because I check the cameras on my iPhone using the Arlo app, the browser choice is not relevant, correct?
Thanks for your help.
Correct, I didn't see the device mentioned in the OP...
But you could attempt to try on a browser/pc to determine if it is the GO or the phone. ( if the system is functional out side of phone , it would then point to phone or app issue )
The app. In Settings, at the top, is a section labeled My Devices.  The camera is found there.
StevenPaul,
Are you accessing from the primary account or a shared account? If the account is shared, it sounds like you may not have access rights enabled.
  • 7 Replies
  • 8014 Views
