  • 1 Reply
  • 2367 Views
WA001
How does sd card recording get activated? Can live streaming be saved?
No, streaming can't be directly saved.  If you want to do this, you'll need 3rd party screen capture software to record your screen while streaming.
The SD card records what is sent to the cloud when activated by motion or sound detection. Manual recordings aren't captured.  It will continue to record even if Internet access is cut but won't upload those when service is restored.  You would need to unmount the card and view those videos on a computer.
  • 1 Reply
  • 2368 Views
