  • 1 Reply
  • 3284 Views
5g
AT&T ARLO GO (4g LTE) Firmware 2.5.2_21629 6/4/18. Netgear solar panel VMA4600.
Continue to get solar panel charging error.
How does this system work?
I measured A.C. adapter output to be 5v.  Are there commands or should D+ and D- on usb conector be shorted to produce the 9v output?
Same with solar panel: panel outputs 5.3v open circuit.
What is required for A.C adapter and panel to output 9v?
Does the firmware short D+ and D- to produce the 9v?
Joel
5g,
Take a look at this article for more information on using the Solar Panel with Arlo Go: How does the Arlo Solar Panel work?
If you're seeing an error message, you might take a look at the troubleshooting steps here: My Arlo Solar Panel is not charging my Arlo Go or Arlo Pro camera battery; what do I do?
  • 1 Reply
  • 3284 Views
