Can I remove battery and run Arlo Go directly from wall charger? Is charger jack waterproof?
  • 6 Replies
  • 2578 Views
littleboss
Can I remove the battery and run the Arlo Go directly from the wall charger?
Is  the jack on the Arlo Go that the charger connects to waterproof?
6 REPLIES 6
yes, it will run on ac.
If I remember right , NO... the ac cable into the Go is NOT weather resistance.
You could if wanted of course use some form of sealant, but that's up to you.
littleboss
I can use silicone like I did on my Go Pro. Will it work without the battery? If I connect it to a 24 hour timer that reboots it once a day will it come back online without me having to be there to do anything?
It should come back automatically.... but I would test it first before placement
littleboss
Thanks,  I guess I will have to buy one and try it
Vlh23
So, yes it runs on ac, but the question was, will it run on ac without the battery in?
Re-read message 2. The answer is yes.
  • 6 Replies
  • 2579 Views
