  • 6 Replies
  • 2484 Views
  • 5 In Conversation
MiliuVLC
Hi!
My camera Arlo Go has stopped sending push up notications when movement is detected.
I haven’t applied any configuration change. I tried to uninstall and install the camera again and the problem is still there.
It seems the motion detection feature is not working. Anyone having the same issue?
Thank you
MiliuVLC
 I tried it but still not working.
Finally I found the solution:
- Remove the battery
- Wait for some minutes
- Install the battery
- Remove the device from the app
- Install the device again
Best.
6 REPLIES 6
Did you try the motion detection test? https://kb.arlo.com/1114344/How-do-I-use-the-motion-detection-test-for-my-Arlo-device
hurstolds1
Mine stopped as well on 5/18/2021?
JessicaP
Hi hurstolds1,
Have you tried what StephenB suggested above?
MiliuVLC
Best.
SteffiB
Hey,  I’ve got the same problem. One of three cameras stopped motion detection this night.
hurstolds1
I rebooted the Smart Hub and this solved the problem with the doorbell notifications.
  • 6 Replies
  • 2485 Views
  • 5 In Conversation
