Arlo go not charging with solar panel
  • 1 Reply
  • 1401 Views
Bestshooter
I have an arlo go hooked to a solar charger and it does not charge my battery at all . How can I test it to see if it’s even working or how can I charge my battery?
If you have a multi meter, with some small wires, you can test the output of the panel.... it should be by touching the two outer contacts in the cable end that plugs into the camera,,, about 6v should be seen in full sun.
Also remove and replace the cable several times ( be careful ) as it may clean the contacts if dirty.
  • 1 Reply
  • 1402 Views
