Arlo Go won't connect
  • 2 Replies
  • 10067 Views
brunborg
So my Arlo Go won't connect.  I've disabled the pin on the sim-card, and it gets online without problems put in a phone (tested on Samsung and iPhone) - so it should be getting online OK.
Tried and re-tried several times over a two-hour period, I scan the QR on the package with my phone, OK, then generates a QR code to be scanned by the camera, and after a while it plays four descending notes - definitively not a "chime" sound but rather a "you have lost a life"-sound. The blinking changes from a "slow blinking blue" to a "rapidly blinking orange" - this happens even if there is no QR code in front of the camera.
"Fast blinking orange" means the camera is connected to the mobile network but cannot connect to the cloud. I checked Arlo status () and it says "All systems are operational" and "All good".
So... what am I doing wrong here? Shouldn't it be possible to manually pair devices by punching codes or something?
EDIT: I have also tested the factory reset via QR. That playd a chime, but still the same result.
brunborg
Got help from support, the fix was to take out the battery and pair it with just the power plugged in.
ShayneS
Hi @brunborg
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
brunborg
  • 2 Replies
  • 10068 Views
