Arlo Go will not detect motion
  • 6 Replies
  • 3539 Views
Macimae
Arlo go will not detect motion. Fails motion test. No amber light. Can this be fixed?
6 REPLIES 6
No. However, how are you testing for motion detection? Are you withing ~20 feet of the camera and moving side to side?
Macimae
Yes
Macimae,
You could try removing and factory resetting the Arlo Go. After the reset is complete, add the camera back to your account as if it were new and test again to see if you still experience the same behavior.
https://kb.arlo.com/1202749/How-do-I-reset-my-Arlo-Go-camera-to-factory-default-settings
Macimae
Thanks. I tried that and it did not work.
This could indicate a hardware issue with the camera. How long have you owned it?
Macimae
I believe it is a defective sensor. The camera is only 2 1/2 years old. I was told by Arlo that it is not fixable and I would need to buy a new camera. I will not buy another Arlo mostly because of their horrible customer service. Also a four hundred dollar camera should last longer than 2 1/2 years!
  • 6 Replies
  • 3540 Views
