Arlo Go sync button does not work. Does not click so can't get any further.
  • 2 Replies
  • 4580 Views
moprabbit
I m trying to set up my arlo go camera again after it's not been working properly. But when trying to press the sync button it does not click (like the camera sound) so can't get any further with the set up process.
JessicaP
Hi moprabbit,
You might need to try doing a factory reset if you're having problems with your Arlo Go: Arlo How Do I Reset My Arlo Go Camera To Factory Default Settings? 20 people found this helpful in l...
Otherwise, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
JessicaP
Hi moprabbit,
moprabbit
Thank you for your reply. I contacted Arlo support and after trying various things they said the camera was faulty. I sent it back and got a replacement.
  • 2 Replies
  • 4581 Views
