  • 3145 Views
Ixnowx
My Arlo GO camera triggers too many motion notifications. Camera is fixed on a beam, no wind, no trees there’s nothing around it that moves. All I notice on the videos is a change in light (day time) like a shade. But there’s nothing around it that casts a shade. It’s consuming all my minutes.
It's possible that the sun's IR i sbeing reflected. What is your sensitivity setting for motion? Try reducing it (80% is the default) significantly until the false trigger cease and then slowly raise it until satisfied. You may need different settings for different times of day so create multiple modes and schedule them appropriately.
fivehands
How do I change the default to make it less sensitive and could I have a delay after each motion is detected
There are FAQs here with full details, quickly use the Mode tab, click on your camera and edit your modes (Armed by default). All settings are in there including sensitivity. However, there's no way to set a delay between recordings - if motion continues, a recording will end, a short delay while the system resets and then more recordings. Sensitivity would be the only way to minimize the recordings although camera positioning may help.
  • 3146 Views
