Hello, I am considering getting an Arlo Go with Verizon service to monitor a residential constuction project for a new house. The camera will likely need to be ~75ft away and I am not sure the motion detection will work. Can it be set to record on a schedule with motion detection off? Also, can it be set to only record to an SD Card and not cloud? Thanks
Yes, 75 ft is a bit far and detection may not work
No, you can not schedule a record ( tho you can do it manually )
No, it goes to both at the same time
Thanks. Hope that is something that can be fixed with a software upgrade
Modes et règles
