Arlo Go and Pro 5 2k togehter in one app?
  • 1 Antwort
  • 348 Aufrufe
  • 2 in Unterhaltung
hamburgerjung
Hi, I have 4 arlo Go running and like to add 5 Pro 5 2K to the setup. No base or hub, just the app.
During the setup of the new Pro 5 2k the app requires the new version, but gives also a warning, that the "Go" is no longer supportet/need a new firmware. The Go-cameras are on the firmware (1.096.3.2_1.8.65.0_16) and is showing that is current version.
How can I run the existing cameras an the new ones with the same (android) phone?
1 ANTWORT 1
BrookeN
The Arlo Go will not be supported on the new firmware. You can create a separate account for the Pro 5.
  • 1 Antwort
  • 349 Aufrufe
  • 2 in Unterhaltung
