Arlo Go additional cameras
  • 1 Reply
  • 4633 Views
Thenewchapter
Enjoying the NEW Arlo Go.  Two questions:
1. What options do I have to buy additional cameras to compliment Arlo Go?  Can I order the Arlo Pro and use the Arlo Go as the basestation or do I have to order addtional Arlo Go cameras only?
2.  If I have a website of a golf course, is it easy for customers to link into the Arlo Go to check current weather conditions?  Do I just copy/paste the URL from the cloud into a section of my website?
Thanks everyone and Thank You Arlo for staying progressive and innovative.
TK
The Go is a standalone product. Nothing connects to it nor will it connect to anything else.
For others to access it, they would need to use the app or a browser using communal credentials which could be an issue. You could use a web link to point to the Arlo website but they'd have to log in like you would. To keep things safe, you would need to set up a friend account using an email address that's likely not used for anything else. A bit clumsy but could work.
  • 1 Reply
  • 4634 Views
