my arlo go has been in the same spot for a year now, I use the arlo data plan, for the past two weeks it went off line and tells me move to mobile coverage, the area it is at has good reception, i get 5 bars of service on all my other cameras, what could be wrong, i also will mention that i use a solar panel to keep it charged, and just put a new battery in it last month
Have you tried to reboot this device & test again?
I could not reboot because the camera was off line, and must mention the camera is 3 states away, so getting to the camera is not possible, if it goes back on line i will try to reboot
Not that it helps right now but a WiFi switch such as a Wemo would allow you to reboot the base remotely.
Modes et règles
