Arlo Go Has Erratic Solar Charging
  • 4 Replies
  • 2859 Views
Vernmuller
With the camera fully charged, the percentage gradually drops over a few weeks even though the solar panel is showing a charging symbol during sunshine. I keep the camera off excpet for when i want to look at a live picture every couple of days. When it gets down to 0% the camera goes unresponsive. It comes back to life after a few weeks when it has charged back up to 100% then the cycle starts all over again. Any thoughts?
How's the signal to the cell service? If the signal is weak or intermittent, that could deplete the battery faster than normal due to trying to maintain the connection. The panel is just a trickle charger so has limited output. Of course, it could also be that something is defective. In that case, open a case with support here.
Vernmuller
Whenever i check it says 3 out of 5 bars which seems good enough. Why would they supply a panel that cant keep up with the consumption. Sounds like i better put a bigger panel on it because I'm 600kms away and cant be mains charging it all the time.
The signal seems good as long as it doesn't drop out for some reason. The other possibility is the amount of recording and live viewing that's being done. Battery life is spec'ed at <5 minutes per day for both - are you regularly exceeding that?
Vernmuller
Please re read the middle of my original post
  • 4 Replies
  • 2860 Views
