  • 2 Replies
  • 1863 Views
BybeeFarms
My system (13 cameras) keeps changing itself out of the Custom Schedule to disarmed or Armed. Trying to figure out what is causing it
BybeeFarms,
Is this happening consistently? Is there a specific interval that you're noticing this or was it a one-time occurrence?
test2
I have 13 cameras and it is doing it to me too. Started after the big update went out to fix the offline issues. I have restarted them, recreated the schedules using the desktop, and checked to make sure they are all set to the correct time zone and still the same result. They either won't arm on time or will disarm hours past when they should. They will only correct when I arm/disarm them manually then the schedule comes back online. Also, the schedules status is always different between reviewing them on the phone and the desktop. There are backend Arlo network issues here.
  • 2 Replies
  • 1864 Views
