Hey,
I've got an Arlo GO which keep changing network all the time, draining battery and going offline constantly.
In the Web UI there is a setting for enabling/disabling Roaming, but the slider doesn't work. Can't even click on it to disable roaming. Any ideas?
If I check the browser network-tab I can also see a lot of site errors, "ERROR TypeError: e.toggleRoaming is not a function" for example.
Hi aewik,
Have you tried removing the battery from your Arlo Go and re-inserting back in to see if that may help?
For me it seems the Arlo web gui is not working when trying to change/disable the roaming for Arlo Go.
Perhaps anyone could confirm if it’s working for them or not?
Changing/reinserting the battery resets the camera to a known configuration.
Verizon and att are upgrading the cell towers… to 4g 4.5 g and 5G. and that could be a cause of disconnects
another reason is its trying to connect to a 3g tower and its a week signal. Causes lots of retries. And ultimately battery goes down.I’ve been there on this issue.
Modes et règles
