ARLO GO - Setting a rule, motion detected on camera A, record on camera A & B - is this possible?
  • 5 Replies
  • 2634 Views
FOLKL
Using Arlo Go cameras to analyse a pedestrian crossing.
When motion or sound is detected on A, I want both camera A and B to start recording.
It seems this type of rule set up is possible on other Arlo cameras, but not the Go?
5 REPLIES 5
I suspect the issue is that the Go (and Q) cameras are unto themselves so can't be cross-triggered as you need. I don't have 2 of either so can't test but when you create a rule for one camera you can't use Add Device when editing that rule for the other camera on your account?
FOLKL
Thanks @jguerdat for the reply.
I tried adding a further device when setting the rules in the mode creation but it wouldn't allow me to add another camera.
This would be a extremely useful feature when using multiple Arlo Go's to cover one area. Hopefully the development team would look into this?
FOLKL
Hi @jguerdat Have received a response from Arlo who state "Custom mode should work with your Arlo Go cameras.
Please make sure your 2nd Go camera mode should be Armed as well."
Certainly isn't working in practise.
FOLKL
additional screen grab:
Based on support's reply and your screenshots, it would appear that you need to continue to create the mode, choose a camera to start with and then use Add Device when you get to the summary page to also trigger the second camera. That's how you would add the ability to cross-trigger. If no other device is shown then it isn't possible.
  • 5 Replies
  • 2635 Views
