Unable to link arlogo2 to WIFI or base station
This message is sent here because the update button does not work. Case Number: 00729695
My previous update appears to have been ignored- copied below.
I have also tried to link my ArloGo2 camera to my Arlo base station without success.
This camera was previously used through a sim card as it was in a remote place, does this have any issue with now trying to link it my WIFI?
It has been replaced at the remote site with a Reolink camera and solar panel. This camera is kept fully charged with its solar panel - your solar panel and camera completely failed to do this as I have informed you many times
Before next installation attempt, also make sure to:
Disable any VPN. DONE
Enable location services on the Smartphone. DONE
Disable Mobile Data (If onboarding using mobile device).DONE
Your device is connected by Wi-Fi to the network you would like to pair it with. DONE
Fully charge battery. DONE
Be ~1 meter from router during installation. DONE
Double check, if password put correctly during installation process. DONE
Disconnect all devices that may use Wi-Fi for the time of installation. DONE
Unplug all Wi-Fi extenders/Signal boosters for the time of installation. DONE
If Arlo still fails to discover your device, try to install it using different mobile/PC device. DONE
Hello,
I reached out to support regarding the case you had listed above. They will be reaching out to you as soon as possible.
Non of your suggestions have helped, camera will not link with Wi-Fi or base station. I get the blue flashing light and the chimes. But searching for camera fails. I have done this process many times with other cameras successfully
None of whose suggestions? I don't see anything here.
When you see the blue flashing LED, describe what it does - slow flash or rapid? Does the camera show as connected in your router's connected devices list? Are you using WPA2 (AES) encryption? Do the SSID and/or password include any special characters including spaces? We need all details of your process.
