  • 2 Replies
  • 1231 Views
Monie
the spiders on the camera lens Spider web I wipe my camera lens every day! Can you recommend something so that the camera lens cannot be covered with cobwebs is it very annoying with spider webs on the camera lens?
Dannybear
I have not seen anything from arlo regards recommendations.
If you google the question you get a variety of answers to try out.
The important thing is not to impact the camera face as plastics can be degraded with oil or acid based products.
The simplest answer seen was to place a flea repellent collar over the camera to keep away insects that spiders are attracted to.
Monie
I thank you very much for your suggestion;-) I will try your flea repellent collar suggestion
Many thanks for the suggestion
Yours sincerely
  • 2 Replies
  • 1232 Views
