Mobile provider and country
Hello dear,
I live in Beirut-Lebanon. Can the camera be operated in this country if it is not listed with the other countries?
and do the local sim card providers (not listed with AT&T or Verizon or so) be compatible with the camera and operate notmally with any local sim card provider?
thank you
The camera can be used but there are no subscriptions available there for cloud recordings. You would have to use local storage with a microSD card inserted in the camera to record but then you would need to eject the card for viewing on a computer - there's no way to view them directly.
The SIM card may be an adventure to determine what would work for you. I'm no SIM card expert so you may have to experiment. The camera does connect to your WiFi, too, if that would be useful.
