  • 9 Replies
  • 424 Views
  • 3 Likes
Ossyguy
Hi. I have 3 go2 cameras monitoring a building site and the day before Easter break, they have all decided to not connect via LTE 4g. There is no WiFi onsite. I have spent 8-9 hours trying to connect them with no luck.
Jonzey3000
I too had a camera that has been working fine for years and it suddenly disconnected and wouldn’t reconnect. ended up setting the APN to telstra.internet manually and it worked.
9 REPLIES 9
BrookeN
Jonzey3000
Ossyguy
Hi Jonzey,
thanks for the reply. I’ve seen where I can enter the info, but how do I find out what info to enter in? I have the belong SIM cards. Thanks
Jonzey3000
Mine is with belong too (perhaps it’s an issue specific to them) telstra.internet is what worked. Also I connected mine to wifi first then changed the APN when trying to connect to mobile network. Not sure if this is required.
Ossyguy
It worked. Just entered telstra.internet in. I was at my wits end with them. Thanks again. You’re a legend
thedrover
Guys
I'm having the same issue connecting the Arlo go2 camera's to Belong network. I can't find the spot where I add the Telstra APN info. Can you explain how I get to this page.
Jonzey3000
For me it’s settings (gear icon)> cellular network > APN settings.
I can’t recall where it was prior to pairing but I think I connected the camera via wifi first, then I was presented with APN settings option when changing to cellular.
Ossyguy
 when you try and connect, then it times out, this screen pops up. Just enter telstra.internet into username I think, then try connect again.
thedrover
yes needs to fail to connect and then allows you to add in APN
I've been talking to the Arlo help desk for the last 3 weeks and they have told me it's a bigger software issue that the engineers were working on however don't have a fix and I then stumbled across your thread and boom fixed in 5 mins.
Great really appreciate your help
  • 9 Replies
  • 425 Views
  • 3 Likes
