GO 2 Connects with wifi but not with LTE
I have a (VML2030-100EUS) in the Netherlands. Tried two different (activated Sim's to connect to LTE, one data sim and the one i use for calling and data) . Result: No camera found. Wifi connection works. Thanks for your help.
Are you using a Vodaphone or KPN SIM card?
Probleem solved after I removed the sim pin. Thanks. Should be in the manual.
