  • 2 Replies
  • 320 Views
JanArlo
I have a (VML2030-100EUS) in the Netherlands. Tried two different (activated Sim's to connect to LTE, one data sim and the one i use for calling and data) . Result: No camera found. Wifi connection works. Thanks for your help.
BrookeN
Are you using a Vodaphone or KPN SIM card?
JanArlo
Probleem solved after I removed the sim pin. Thanks. Should be in the manual.
  • 2 Replies
  • 321 Views
