Dear Community, do you know if it's possible to combine a Go2 (with sim card) with a Pro5 (with wifi) within the same network? Thank you
Generally, yes. They won't be on the same network unless the Go 2 is close to your WiFi so you can connect both cell service as well as WiFi. Mine is only on WiFi and works with my Pro 5.
