Cellular camera connect to base station
  • 1 Reply
  • 1558 Views
mrosenbrock
I have an Arlo Go camera connected via LTE with Verizon, and my home LAN is connected to the internet via AT&T. There is some distance (out of reach for WiFi) between my home router and the Arlo Go camera.
My question is, is it possible to point the cellular camera to my home network, then to my local storage devices. If I could get the traffic from the camera to my home router, I could figure out the rest, but I'm kinda stuck.
No. Neither Go cameras (Go or Go 2) can use a base or hub local storage. However, the Go 2 supports using a microSD card for its own local storage. You must eject the drive to view the recordings on a computer because the app doesn't currently support direct access.
  • 1 Reply
  • 1559 Views
