  • 2 Replies
  • 2879 Views
BerowraRam
Arlo Go2.  Do I need a sim card as I just want to add to my existing contract and use the camera at another house using their WIFI
If you aren't interested in using mobile data, then I suggest getting a different camera. Both the Essential and the Pro 4 would do what you need - and both are considerably less expensive.
The Go2 can connect to WiFi also - that should work without a mobile data plan.  Not sure if the camera will work properly without a SIM card though.
I happen to have a Go 2 on WiFi only - no SIM card - and it works fine.
  • 2 Replies
  • 2880 Views
