Battery doesnt charge arlo go 2
Hi, im having Arlo go 2 already for almost 2 years, everythong worked fine, last week i took it of the wall to recharge, and it doesnt recharge anymore, i done a restart multiple times, nothing happens, orange light sometimes bipes for asecond
Did you let the battery totally deplete? Try this FAQ - the key is to plug in and unplug many times to get enough charge into the battery to then let it charge normally. Recharge proactively to prevent this.
nope, tried it multiple times, still doesnt charge
It could be a faulty camera or battery. A possible solution, assuming the battery is ok and the camera isn't actually dead, is to use the external charging station. A second battery could also be useful but be sure to have a return privilege.
had same issue you will find the outer case terminals are corroded and shorting inside the case - I have 3 units all have done it and Arlo sell spare cases so clearly aware of crap design - its poor design - test continuity between terminal connection without the camera and you will see its not open circuit and a short will exist. hence battery runs out super quick and wont charge
