Arlo Go2 Using 5G network
Cannot get the Go2 to work with WiFi. Using 5G network. After it “chimes” it tells you to wait, but always comes back after I wait with the option to retry.
Also, cannot find an audio trigger in the RULES section for the Go2. It only has motion triggering as a selection. I have the latest app version 3.5.8 and newest firmware.
Any help would be welcomed.
Do you mean a 5G mobile network? Or a 5 gHz WiFi network? The Go2 uses 2.4 gHz WiFi. Also the network needs to be secured a password (WPA2).
Are you using unusual characters in the WiFi name or passphrase?
This camera is brand new, has paired successfully with the App, and was working great on the LTE network a day earlier.
Thanks for your help
Spec7op,
The symptom you're describing (delay in establishing a live stream) indicates a connectivity issue or poor WiFi/Mobile data speeds. If the motel WiFi or mobile data connection is poor or slow, this would be the result.
