Replaced an Arlo Go with an Arlo go 2 camera that had 24 hour cloud storage for recordings that was good enough for what I use the camera for. The Arlo Go 2 will detect motion but does not record anything to the library and when I go to the library it has an advertisement for Arlo plans. The go camera you could use without a plan. My question is what is the lest expensive plan where I can get 24 hours of storage minimum? If you do not need a plan how do I get the camera working again? Don’t want local , need something in case the camera is stolen.
A single camera Arlo Secure subscription is cheapest.
Pricing depends on the country, and is shown here:
US pricing is currently either $4.99 per month, or $47.88 annually. Note if you cancel, there is no rebate - one disadvantage of the annual subscription plan.
Thanks!
