Arlo Go 2 Streaming Specs
  • 1 Reply
  • 1767 Views
SilentPug
Hi guys,
I have some specific needs before I purchase a Go 2, wanted to know if any of you know details about the different video quality. Ie. Resolution, fps, bitrate
Select a setting:
• Best Video. This setting might reduce the battery life.
• Optimized. This setting balances video quality and battery life.
• Best Battery Life. This setting might reduce the video quality.
tsitalon1
I can confirm that both Optimized and Best Video are producing the same streaming output which is disappointing:
1920x1072
600-700Kbps
24 FPS
I cannot confirm actual SD card file properties as my camera is 20' off the ground and not easily assessable.
I think this is a FW bug.
Arlo Team, can you confirm if "Best Video" should result in a higher bitrate recording uploaded to the Arlo Cloud?
  • 1 Reply
  • 1768 Views
