- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Go-2-QA-2021-04
- Is the charging port going to be a micro USB like ...
Is the charging port going to be a micro USB like the original Arlo GO or a Magnetic mount?
Options
- Mark Question as New
- Mark Question as Read
The original Arlo Go charging port would get corroded within a year and then you had to replace it. If the ARLO Go 2 has a magnetic charging mount, have you tested it to see if it is more durable than the micro USB?
Accepted Solutions (0)
Answers (1)
Answers (1)
Arlo Go 2 uses a magnetic charging solution, the same charging solution used for Arlo Ultra, Pro 3 and Pro 4 cameras. For a better idea of how this works, take a look here: https://kb.arlo.com/000062136/What-is-the-magnetic-charger-that-came-with-my-Arlo-Ultra-or-Pro-3-cam...
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
0
Likes
