- English
- Cameras
- charger cable misplaced - any way to charge using ...
charger cable misplaced - any way to charge using mobile phone charger cable until original found
Our charger cable has been misplaced. can we use another (mobile phone charger) cable until the original cable is found?
The battery level of out arlo device is below 25%.
Is there anyway we can charge the device (AVD2001Aer1.2 Wirefree) with a mobile phone charger cable for example temporarily?
That should work fine. Cables can be a bit of an issue since some have more plastic around the connector making it impossible to seat properly so verify all is well when plugged in.
It worked out fine.
Actually, the charger was also misplaced along with cable, so we needed to use a charger and cable from mobile phone.
My sister did the charging. From what she said, it was a bit slower than using the charger (and cable - does the cable affect charging time? I don't know) that came with Arlo device. Took 1 hour to charge from about 20% to 48%.
ANyway, all good. Thanks for the response.
The charger certainly can make a difference. You want a charger that delivers about 10 watts (2 amps @ 5 volts).
The cable also sometimes matters. The resistance is one factor - thin internal wires or a long cable length will make resistance higher. That results in more power loss in the cable, and therfore a slower charging time.
FWIW, The gen 2 essentials use USB-C cabling. The USB-C spec is complicated, and USB-C cables don't all support the fast charging feature, or might have a charging power limit. Not sure that matters with the Gen 2 cameras, and it doesn't apply to the AVD2001.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
