camera offline
I think my camera is a 1st generation, but helpfully it does not say so on the camera which is about 3+ years old. I have found it impossible to actually contact/speak to anyone at Arlo other than a useless chatbot, which I think because I have a basic plan i.e no subscriptions, the bot is the furthest I can get. I can't help thinking that if I were to be buying something they would be all over like a rash! So the camera suddenly decides to go offline, I cannot sync it with the base station as it won't find it, I removed the device to reinstall it, but the phone (android), app will not recognise the QR code, I am going round in circles and going nuts, yes it is fully charged. Any suggestion from anyone please?
2nd gen Essentials
- have a sync button on the top
- use a USB-C port for charging
- Have the VMCxxxx camera model printed on the back.
1st gen Essentials
- have a sync button on the bottom (right in front of the charging port)
- use a microUSB port for charging
- have the VMCxxxx camera model embossed on the charging port flap (it is hard to see!)
Installing the cameras doesn't require the app to read a QR code. So I am puzzled on what you are doing. Normally you just go into "Add device" (being careful to choose the right model).
You could try a hardware reset - holding down the sync button until it flashes amber - about 15 sec.
Thanks for the reply, I have tried a factory reset, I've tried just about everything QR code and via base station, no joy, at a total loss, I think arlo is going to be ditched spent way too much time and energy on this. Thanks anyway.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
