camera offline
  • 2 Replies
  • 345 Views
French65
I think my camera is a 1st generation, but helpfully it does not say so on the camera which is about 3+ years old. I have found it impossible to actually contact/speak to anyone at Arlo other than a useless chatbot, which I think because I have a basic plan i.e no subscriptions, the bot is the furthest I can get. I can't help thinking that if I were to be buying something they would be all over like a rash!  So the camera suddenly decides to go offline, I cannot sync it with the base station as it won't find it, I removed the device to reinstall it, but the phone (android), app will not recognise the QR code, I am going round in circles and going nuts, yes it is fully charged. Any suggestion from anyone please?
2nd gen Essentials
  • have a sync button on the top
  • use a USB-C port for charging
  • Have the VMCxxxx camera model printed on the back.
1st gen Essentials
  • have a sync button on the bottom (right in front of the charging port)
  • use a microUSB port for charging
  • have the VMCxxxx camera model embossed on the charging port flap (it is hard to see!)
Installing the cameras doesn't require the app to read a QR code.  So I am puzzled on what you are doing.  Normally you just go into "Add device" (being careful to choose the right model).
You could try a hardware reset - holding down the sync button until it flashes amber - about 15 sec.
French65
Thanks for the reply, I have tried a factory reset, I've tried just about everything QR code and via base station, no joy, at a total loss, I think arlo is going to be ditched spent way too much time and energy on this. Thanks anyway.
